Hey all, as you've probably seen I'm getting a new '09 electra avl next thursday.
I've been reading that sprag failures are more common in cold weather. It's in the mid thirties in baltimore right now. i don't want to ride around in the snow and ice but as soon as the roads are clear I know i'll be dying to take it out. does riding it stock in cold mean i'm basically going to have a sprag failure?
I read on another post that *CMW has a "fix"* some box that you replace on the stock AVL's. The post was from a few years ago and I was wondering if this has been fixed in the '09 Electra. Also, is this something I should look into doing to Prevent sprag failure, or just fix the sprag IF it happens to me?
I've also read that the lean burn engines have more likelyhood of sprag failure. I know it's caused by a kickback when starting the bike, and that it's more likely to happen if I use the ES than the kickstart. I've never kickstarted a bike, but plan on learning quickly, and I was also wondering if you can CAUSE a sprag failure by improperly kickstarting... aka if i go out the day after i get the bike and get it in my head that i'm going to kickstart it and begin the break-in, can i damage the bike by trial and error or excessive improper kickstarting?
Thanks in advance, and any advice is much appreciated. Also, if there's anything above that seems to be not quite correct, just let me know so i can understand better.
cheers,
chuck
