Bess...
18 Guests, 2 Users
Mandar_C500, finbullet
June 01, 2016, 02:30:52 am
Author Topic: Oil Leaks  (Read 756 times)
P. Schraub
Oil Leaks
« on: January 29, 2011, 08:03:15 am »
Hey Folks,
        I have a new Bullet G5 Deluxe that's leaking oil from the airbox. It's a safety issue, as the oil is winding up on my rear tire ! I've traced the leak to a drain hole and hose nipple at the lowest point of the airbox. My question is : isn't there supposed to be another hose routed somwhere from that nipple ?? The crankcase is NOT over-filled. Any help would be appreciated. Thanks,
        P. Schraub
Re: Oil Leaks
« Reply #1 on: January 29, 2011, 08:59:36 am »
I believe she might have been over filled, it's easy to do with these bikes.
jjoe256
Re: Oil Leaks
« Reply #2 on: January 29, 2011, 01:20:49 pm »
It's over filled. Cold, the oil should be barely visible in the window, Even up to low mark will blow oil. Trust me, I went through this with my G-5 . I find 1500-1700ccs with a filter change. If you're dripping oil, your air filter is shot also.
« Last Edit: January 29, 2011, 03:26:12 pm by jjoe256 »
Re: Oil Leaks
« Reply #3 on: January 29, 2011, 04:19:05 pm »
Measure the oil when you drain and replace with same (amount).
Re: Oil Leaks
« Reply #4 on: January 29, 2011, 05:25:47 pm »
These guys are all right - if there is oil in the airbox - it's overfilled ..........
P. Schraub
Re: Oil Leaks
« Reply #5 on: January 30, 2011, 02:06:24 pm »
Hey Guys,
      You all are correct........I screwed up and over-filled ! Thanks for your input and help. I still want to know why there's a hose nipple at the lowest point of the airbox. Could this be for a chain oiler in case of overfill? Or, is it just a drain hole ?
