OK, it seems there is no good reason not to do it.
Any tricks to removing the big nut on the gearbox sprocket (5 speed)? It looks like there is some kind a bent washer behind it. Do you just rely on the rear brake to keep the sprocket in place while you attempt to loosen the nut?
Eamon
Tap that bent part of the washer flat. That is a locking-tab type washer, and you need to bend it back up against the nut after you replace the sprocket and tighten the nut back up.
Then get yourself a big 2" wrench and crank that sucker off.
You will have to use the chain on the sprocket to stop the gearbox from turning when you are loosening/tightening that nut. So I don't take off the chain until I have loosened the nut.
You just have somebody hold the brake pedal down, so that the wheel can't move, and that will prevent the sprocket shaft from turning. Then you can crank off the nut.
When you put it back on again, put the sprocket on the shaft and put the chain on it, and hand-tighten the nut as far as you can. Then have somebody stand on the brake pedal again, and tighten that sucker up. Then bend the washer back up to lock it after it's all tight.
Voila'!
BTW, it's supposed to be torqued to 40 ft/lbs, but I don't know anybody who has a 2" deep socket that deep. I sure don't.
So, tighten it up as close to what "feels like 40 ft/lbs" as best you can, and go with it.
