Ha...I asked the forum first before I started the project, as I always do, but I've discovered with these bikes that no two are alike. That's part of the fun. The right grip took a little bit of tinkering. I had to cut a wider diameter circle for the throttle. I test-fit several times to make absolute sure that there weren't any clearance issues. I had heard horror stories about the lever getting stuck. I also loosened the starter assembly and unscrewed the brake lever and shifted down once. It still didn't provide enough clearance so I did it again. Third time was a charm, and now the mirror is completely firm. All things considered I was pleased with the results, but since it's a slow rolling bike having a mirror on the right isn't as important to me (safety wise) as having the left.
I've been purchasing new projects for the spring this winter (new 7inch headlight, turn signals, taillight, and I also want a new seat. The solo was on the bike at purchase but it is a little large for me. I want the solo with the springs!
