I don't know this particular type of carb, but in cold weather the chances of it being too lean are much greater than it being too rich.
Additionally, while there may be a float level issue, the part about going uphill and having the symptom doesn't necessarily indicate float level problem. On hills, the throttle is open wider to handle the additional load, and that would put you further up onto the main jet, which may be where the problem is.
I would change to the next higher size main jet, and see what happens.
Typically 3/4 throttle to full throttle is main jet territory, and it's cold outside, and you could very well be needing more main jet.
Unless you took your plug reading at a large throttle opening with a plug chop and shut the engine down from that throttle position, the color of the plug is meaningless for assessing this situation.
General rule of thumb is try the next size up, and observe the result. If it gets better, but not enough, then go up another one.
If it gets worse, go down a jet size and see if that fixes it..
