Bullet 350 DLX
53 Guests, 4 Users (1 Hidden)
flyman, Dodd, The Old Coot
May 30, 2016, 11:33:48 am
Author Topic: Deep valance mudguard  (Read 1716 times)
2bikes
« on: January 27, 2008, 09:07:53 am »
Has anyone had trouble fitting the  deep valance chrome mudguard to the disc braked Electra?  When fitting one to mine, I found that the fit was so tight it pushed the rubber gaiters up on the forks.  By way of solution I have cut out a half-moon shaped hole in the stays just large enough to accomodate the gaiters and their clips.  Once fitted, the hole is not noticable.  I put some galvanising paint round the edges of the new holes to deter rust.
  • Administrator
Re: Deep valance mudguard
« Reply #1 on: January 27, 2008, 10:41:34 am »
2bikes,
You are not alone. That is what you have to do to make it work.
President
Classic Motorworks
www.classicmotorworks.com
www.cyclesidecars.com
HRAB
  • I should really edit this
  • Been there, doin' more...God willing
« Reply #2 on: February 01, 2008, 03:53:59 pm »
Another alternative is to use our aftermarket gaiters. This does require a lot more work to install them, but they are thiner and will fit. They also will require some stretching to get them over the lower fork leg.
jim
BMWMOA www.bmwmoa.com
Iron Butt Association www.ironbutt.com/about/default.cfm
(Formerly) CRA# 118N www.cra-mn.com (I got smarter in old age)
74 Honda XL350 'Scoot'
81 Honda CB650C
86 Gold Wing with California Sidecar
00 Honda ST1100 'Large Marge'
LotusSevenMan
  • ...._[:]@==<
« Reply #3 on: February 05, 2008, 02:37:04 pm »
2bikes.
Sounds like you got it all right then by doing this mod!!!!
Ducati 916 'L' twin
