Here's what I've learned from my first Spring, Summer, Fall, Winter with my 2008 AVL Classic starting from zero miles. I did a full dealer prep & a lot of other stuff on it as it had not been sold by its dealer & not started for a long time when I got it in February 2010.
I managed to put almost 200 miles on after I got it all sorted out; all short, break-in trips around town, doing errands, etc.. & a few blazing 40 & 45mph "blasts" down the highway for a few minutes. I have not even BEEN in 5th gear yet. 90% of my starts have been with the kicker. I don't care for electric starts & I don't want trouble later + plus kickstarting gives you a clue to your tuneups + I've had kick only harleys all my life (I'm 73 & still have one) so I don't give a second thought to kicking this little black beauty over or stressing about finding TDC.
I don't use the decompressor AT ALL. I found out it was useless & unnecessary very early on. Even now, stone cold after a week, I can kickstart it in 3 or 4 kicks.
I give it 3 or four kicks (the secret is smooth & all the way down) with the key off.
Then I pull the enrichener out & turn the key on & Don't Touch The Throttle!
Kick through all the way down. Usually in three kicks (stone cold - it's been in the teens & 20s here. Unheated garage) it's running. AFTER it's running, I blip the throttle as necessary. In less than half a minute it wants the enrichener pushed in & it will run fine with just an occasional blip of the throttle.
In the warm weather, it's a one or two kicker all the time.
It has the green TCI unit & the kickstand switch & headlight on jumper are removed. It still has the air pulse thing & the huge muffler. That will go when I have a few more miles on. Possibly next Winter. And a simpler intake also.
And I always kill the engine with the decompressor as Pete Snidal & others recommend. I find that if I shut it down with the key, it will run backwards one stroke & makes that horrible sprag destroying noise. If I use the decomp, it does not do that. It just dies quietly & peacefully.
PS: I love this little bike!
