If moving the lever so you can lower your handlebars is what your after, maybe one of these is all you need. Keeping the lever at hand allows you to keep both hands on the bars when starting (handy in traffic). As for those push button releases, they are not made to see fire and fail quite regularly on pals bikes. They leak at the poppet seal, I have machined them apart, they are made of mild steel. I guess if you pulled it closed instead of letting it blow shut it may last longer Just 2 cents..
