I just bought a 2000 Bullet and have problems starting. The PO had a performance exhaust installed but it was rusted with cracked welds, installed the OE exhaust (included) Also has a pancake air filter. Question #1 what jets should it have and is 24mm the best float level?
I'll reset the timing at .8mm (.033") ASAP
Question #2, I have the bushing kit for the left side shifter but I don't think I have the correct instructions, just crude pictures of two levers. I think there is a more concise set of instructions?
Question #3, the PO said to use 20W-50 in the gearbox however after pouring over the forum it seems this gearbox should use type OO grease (which I have) Will that make it more difficult to kick over? I really am trying to hold down expenses.
Here's what I've done so far:
> It's in the garage at about 45F.
> Cleaned the plug, bead blasted it. Nice blue spark with battery charged
> Replaced the intake hose, head to carb.
> Cleaned the inline fuel filter, replaced the fuel lines
> Fresh gas
> Cleaned the carb, new gaskets,orings, needle and seat. Everything looked
> OK
> Float set at 24MM, accidently ruined the float, had to install new float
> Pilot air screw, turn and a half out.
> Does not flood, just acts like not getting fuel.
> Using the starting procedure in the Snidel manual and on the RE forum.
