My 03' Iron Barrel
40 Guests, 1 User
dopeshaw
May 24, 2016, 03:01:33 am
Author Topic: Change rear springs? (Has anybody done this?) hey C.M.W ?  (Read 3780 times)
« on: January 23, 2008, 09:05:18 am »
Looking into changing the rear springs with the cmw pair. Has anybody done that? The ones on my 05"E don't disassemble. No keepers at the top, Snidal says they are non repairable...Hope I'm missing something really obvious. O.k. whats obvious is you cant change the springs, at least on the classic you cant. Classic should make that known in their web store. Ya,think?
« Last Edit: January 29, 2008, 11:40:29 am by cyrusb »
Nacho
Re: Change rear springs? (Has anybody done this?) hey C.M.W ?
« Reply #1 on: March 13, 2008, 12:52:53 pm »
You might find that changing the front springs to softer ones will have the effect of softening the rear.
This is because when your front wheel hits a bump the bike pivots about its CofG and compresses the rear shocks.  So when your rear wheel reaches the bump the rear shocks are already partly compressed making them feel hard.
Just my $0.02
...and my first post, yay!!
« Reply #2 on: March 13, 2008, 03:14:39 pm »
Allready done, I really should remove this post. Changing the rears was the second best mod I've done so far. The fronts are next.
dogbone
« Reply #3 on: March 31, 2008, 01:02:19 pm »
So... :P   how do you do it ?
99 Enfield Bullet 535
« Reply #4 on: March 31, 2008, 04:48:03 pm »
You need a press of some sort. A plate of something with a 2 inch hole in it( I had 1/2 micarta). Press shock upside down through the hole to reveal a disc with 1 1/8 flats. This the locknut for the threaded top eye. Hold back on the disk and unscrew the eye with a bolt through it. Then ease of with the press. I also had a little vee block for the press ram, so it would engage the bottom eye safely. Try and use some stout but thin material for the plate, you can only compress the spring so far, and a thick plate wont leave you enough room for the 1 1/8 wrench. Its a bitch, but the second best thing you can do to an enfield .PS Get the covers while your at it...
doransignal
« Reply #5 on: June 12, 2012, 03:05:20 pm »
will this give you more ride height on the back? when i have a passenger.  the bike drags on the center stand in turns. how can i fix this i have the adjuster all the way up.
Lwt Big Cheese
  • Getting there, slowly...
« Reply #6 on: June 13, 2012, 02:00:28 am »
Get a slimmer babe on the back  ;D
No warranty implied or given.
May contain nuts.
« Reply #7 on: June 15, 2012, 07:11:48 am »
The springs I changed to were softer, so this wont help in your case. Those stock springs were really stiff, if you need stiffer ones you may want to look into LWT Cheeses mod. ( I believe a good one, no matter what you ride).
« Reply #8 on: June 15, 2012, 12:10:04 pm »
The best bet is just to get a set of Hagans. The Enfield shocks have too much compression damping, too. But I'm sure the softer springs can help a lot.
GSS
« Reply #9 on: June 16, 2012, 09:28:19 pm »
+1 on the Hagons
2014 GT - Red
2010 C5 - Teal
It's a Jeep thing......
