Author Topic: 18 Tooth Sprocket  (Read 1379 times)
P. Schraub
on: December 26, 2010, 01:50:36 pm
Hey Folks,
     Just became the proud owner of a UCE G5 Deluxe Bullet. The most important upgrade I can recommend is a change from the 17 tooth counter sprocket to the 18 tooth sprocket. This puts the engine at a comfortable pace on the freeway without over-revving. I can hit 85 mph easily and cruise all day at 70 mph. Thought this might be of help to new owners like myself !
        P. Schraub
mikail gransee
Reply #1 on: December 26, 2010, 07:11:59 pm
This is an old "trick" to get more speed..but watch out for those hills.  ;)
-"ONCE YOU STOP CONTRIBUTING, YOU BEGIN TO DIE",   -ELENOR ROOSEVELT
1999 Enfield Bullet
1977 Yamaha xs360 TD
1978 Yamaha xs 400 D
2005 Yamaha YZF 600R
2007 Honda CBR 1000RR
Maturin
  • My Precious
Reply #2 on: December 26, 2010, 09:33:32 pm
Hi Schraub!
Welcome and thx for this recommendation, I changed aswell and was just as satisfied with the result. I have to add, however, that the 46 mm sprocket was quite reluctant to move and had to be persuaded with a air pressure impact wrench with 500 Nm.
This and many other technical issues are dealt with in the UCE-section in this forum above. Have a look!
2010 G5
Walter Röhrl
