Keep it simple, after all, it's only an Enfield.
You need only 3 things for sucess.
1. Fuel
2. Spark
3. Compression
It sounds like you have fuel as you can smell it at the exhaust.
Check the spark by removing the plug and laying it on the pot , as mentioned above, and hitting the starter
Put your thumb over the empty plug hole and hit the starter. You should not be able to keep your thumb on there if you have compression. You should also be able to feel the compression with the kick start with the plug in place.
Also, while the plug is out, you should be able to smell the petrol if it's there.
All that being said, the Electra does not like a low battery but you say you've charged it. I assume it cranks the engine well?
Don't be embarassed if it's the side stand down; we've all doen that once!
