1937 1100cc Model KX
May 26, 2016, 09:42:31 am
Author Topic: Wheres your kicker pedal?  (Read 2497 times)
« on: January 20, 2008, 12:19:23 pm »
I guess this is more for the "kick only" guys out there. I noticed if I mounted my kicker arm more upright, say were it lines up with that big through bolt in the frame,starting is much easier. Mine originally was laid back, and because of this I wasn't getting a full stroke . Of course as with everything there is a trade off ,and that is now the lever arm is closer to my ankle while riding. I don't mind that ,but finding a comfy spot that still gives more stroke would be an improvement for anyone. Now that I am stroking the full 180 degrees one kick starts are the norm.
Re: Wheres your kicker pedal?
« Reply #1 on: January 20, 2008, 04:55:10 pm »
I think some folks move em back to get more ankle room.
Both of mine were lined up with the big bolt.
Ditto on the kick starts.
fredgold52
  • Macomb, IL Flatlands Rule
« Reply #2 on: January 20, 2008, 10:25:36 pm »
I kicked mine today from a 'not seated on bike' position.  This allowed me to kick it further through the stroke  and it fired right up.  I'm still working on the kicking it "while straddling the bike" thing.  It looks much cooler.Real bad-asses don't use the estart or stand off to the side of their bikes.  This is a man thing.
« Reply #3 on: January 21, 2008, 02:57:58 am »
LOL.
I had this dilemma too. If I fitted where it gave a good healthy swing it annoyed the cr*p out of me while riding. The best compromise for me is as I have it in the pic below. I can do the man-on-bike-kick-start-first-time job like this and not have it interfering with my ankle/back of calf muscle etc  ;D
portisheadric
  • 2015 Forest Green B5
« Reply #4 on: January 21, 2008, 06:57:14 am »
I had a similar boot clearance problem, so after slightly reducing the length of the left hand footrest I fitted the longest tube spacer I could behind the right hand one to provide more clearance between where your foot sits and bottom of the kickstarter.
This allows the kickstarter to be repositioned to give a more efficient swing, without interfering with your foot when at rest.
TPS @ 0.610 volts. Handful of LEDs fitted and an NGK plug and cap, otherwise standard.
« Reply #5 on: January 21, 2008, 09:36:41 am »
Longstrokeclassic.
That sounds like a sensible move and one I shall investigate further. Thanks!  :)
scoTTy
« Reply #6 on: January 22, 2008, 07:29:23 pm »
well. at least it's not up my trousers' leg..  ;D
http://www.enfieldmotorcycles.com/forum/index.php/topic,892.0.html
