00 Military
May 04, 2016, 10:35:44 am
Author Topic: EM Light  (Read 915 times)
hocko
EM Light
« on: December 06, 2010, 07:31:01 pm »
I just went of a 60km ride. After fueling up, I turned on the ignition, no Eng. Man. light. the fuel pump primed and I started it as usual. I checked it and found the the low fuel light bulb and the engine man. light bulbs were flapping in the breeze attached to the wires. I put them back in place, now the EM light stays on solid, no codes flashing etc. I rode the bike back home normally, ran fine just that bloody light staying on. I'm thinking a short somewhere maybe up in the headlight or where I pushed the bulbs back in. Anyone else had this occur, any suggestions before I attack the headlight and wiring, not electrically minded.
Cheers  ???
r80rt
  • C5 Pilot
Re: EM Light
« Reply #1 on: December 06, 2010, 07:33:55 pm »
Is Royal enfield lit up too? I think you have the bulb locations switched. there are three in that gauge.
Iron Butt Association
hocko
Re: EM Light
« Reply #2 on: December 06, 2010, 07:47:22 pm »
I forgot about that, check it out and let you know
Thanks
hocko
Re: EM Light
« Reply #3 on: December 06, 2010, 10:21:05 pm »
You sir are America's answer to the Bullet Wallah. First place all THREE bulbs in the correct sockets and all shall be right in the world Thanks again r80rt.
Cheers  :)
prof_stack
Re: EM Light
« Reply #4 on: December 06, 2010, 10:23:46 pm »
Another free service of this great forum!   ;D
ScooterBob
  • Yeah - I get it ....
Re: EM Light
« Reply #5 on: December 07, 2010, 07:01:25 am »
They often come that way from Raj for no extra charge ......  ::)
r80rt
  • C5 Pilot
Re: EM Light
« Reply #6 on: December 07, 2010, 07:39:35 am »
Glad that was it,  :)
hocko
Re: EM Light
« Reply #7 on: December 08, 2010, 05:02:24 pm »
Thanks again, now if I can only get the indicators to stop flashing when I hit the foot brake !!!!... Just joking.
Cheers  ;D
