Ok, so while I am waffling about whether to sell my enfield (waffle waffle waffle), I have been doing a little maintainence.
To that end, I made my first attempt at retubing a flat tire ever in my life. Done lots of things with bikes, but somehow that one I always left to professionals. But, since I want to be a long haul independent rider, I figured I oughta learn. Successfully used the tire irons and whatnot, got the tube on, and successfully pinch a hole in it while remounting the tire.
So...gave up and ran it to the local hondakawazuki shop to have them do it. 2 hours later, pretty fully inflated tire.
Figured while the tire was off, I would tighten the drive side as the chain was slack. The drop the wheel on, align the non drive side, and go. However, I now have a serious wobble when riding. Have been playing with alignment adjustments all afternoon to no success.
Is it possible that the wheel needs balanced? Should I just pop it off and run it back to the shop and ask them to check the balance?
I only ask, because it seems people do roadside changes like this all the time and just ride on. What have I done wrong? (I have read extensively the other posts on alignment, and have followed all their suggestions...)
Thanks all
-Milk
