Windscreen 2
May 30, 2016, 12:07:50 am
Author Topic: 2100 miles - a couple issues arising.. normal!?  (Read 2937 times)
Sub
  • Bob's Your Uncle
  • 2010 Black Bullet C5
« on: November 18, 2010, 02:48:23 pm »
oops erased post on accident! here is the short version:
I have been hearing a ticking noise at idle when starting, and my solenoid left me stranded, until I whacked it with a screwdriver and it came back to life.. is it on its way out?!
« Last Edit: November 29, 2010, 02:46:11 pm by Sub »
Re: 2100 miles - a couple issues arising.. normal!?
« Reply #1 on: November 18, 2010, 03:05:34 pm »
Changing over to a lower viscosity oil (Oh, GAWD! - an OIL THREAD!!) will most likely cure the valvetrain noise when it's cold. The new lifters have VERY little clearance in them and they don't deal well with oil that's thickened by cold temperatures. It'll limber up after you get a few hundred more miles on it and be quiet all the time. See your dealer about the starter relay - I'm guessing that the bike is still under warranty.
REpozer
« Reply #2 on: November 18, 2010, 03:33:26 pm »
Sounds like a hydraulic valve lifter trying to warm/pump up . I wouldn't rev it to make it go away. What viscosity of oil are you using? Does your bike live outside?
REA # 84 ( the first time)
Maturin
  • My Precious
« Reply #3 on: November 18, 2010, 03:37:37 pm »
This is the first time I took a hammering action to a piece of machinery with success.
Congratulation to your sucessfull action, although the usual procedure is:
1) Shout on the bike
2) Call it names
3) Kick it
4) Calm down and praise it to get it into better mood
5) Use special tool No.1 (hammer)
My fathers old VW had the same issue, we ended up opening the hood and hammering the starter quite often - until the day we forgot to put out 1st gear  :o - we jumped away and the starter shifted the car into the rear end of the car parking in front of us... well, well.....
It´s only the starter magneto getting stuck - if you have warranty it´s winter work for the dealer.
2010 G5
Walter Röhrl
« Reply #4 on: November 18, 2010, 03:42:32 pm »
My starter relay had the same problem - a whack with a screwdriver handle fixed it, but it was on the way out. It's been replaced under warranty. I'm told the new ones are a better Jap made version, although my new one looks identical to the original. Couple of others here have had the same problem. Get it replaced - it'll let you down eventually otherwise.
clubman
« Reply #5 on: November 18, 2010, 04:02:41 pm »
Mine is having serious starting issues again. We don't know yet if it's the relay or the sprag clutch, (already replaced once), or indeed something else so I will say no more about it for now. Just coming into this thread all grumpy I guess to say I do wish RE could sort out electric starting. Everyone else has.
« Reply #6 on: November 18, 2010, 04:36:50 pm »
Sorry to hear it Clubman. What are the symptoms this time?
clubman
« Reply #7 on: November 18, 2010, 04:46:15 pm »
Basicallly exactly as before - the starter motor doesn't turn over the engine. Instead of that sound like a horse braying there's just a sort of whirring, no more. After five or six such responses to the button it will turn over and fire. I don't want to believe it's the sprag clutch which was replaced but 1000 miles ago but I suspect it is. Well, it's going back to my dealer to be checked over sometime soon and we will find out. I've no issues with either my dealer or Watsonian's handling of warranty claims but it will be in its 2nd year of warranty from next week and if I'm going to have starting issues on such a regular basis when it's out of warranty then...well, let's not go there.. ;)
« Reply #8 on: November 18, 2010, 05:14:42 pm »
It does sound a bit spraggish doesn't it., starter motor spinning but not engaging.
If it was the relay it wouldn't turn the starter motor at all. I wonder if they fitted the old style sprag last time rather than the new heavy duty one....?
Good luck with it  -  keep us posted.
clubman
« Reply #9 on: November 19, 2010, 06:15:21 am »
Indeed. I also forgot to say that the battery is fully charged and this only happens when it is cold. This seems to exclude anything electrical and point to the sprag. I was told the replacement was the upgraded one too.  >:(
SSR
« Reply #10 on: November 19, 2010, 07:25:42 am »
@Clubman- spinning without turning the engine over is a sure sign of sprag failure. If you are under warranty or not, try to get the new sprag. How to recognise ? picture of the old and new sprag is in the upgrades for C5 thread I had posted earlier.
Sub
  • Bob's Your Uncle
« Reply #11 on: November 29, 2010, 02:45:22 pm »
I've uploaded a video highlighting the ticking noise I mentioned in the first post. Is this normal?! Sounds terrible!
Fast forward to about 1/3rd of the way through..
http://www.flickr.com/photos/40236795@N03/5218582286/
« Reply #12 on: November 29, 2010, 03:09:00 pm »
I don't hear anything unusual.
« Reply #13 on: November 29, 2010, 03:16:07 pm »
To tough to tell for me I have no UCE bike yet.
Yours definitely has far, far less mechanical "music" ;) than my Iron Barrel mill.
Our forum brothers owning Bullets with the new lump can advise you as to what normal sounds like.
clubman
« Reply #14 on: November 29, 2010, 03:36:23 pm »
Sounds fine to me!
