Thanks everyone!
I´ve been thinking of buying 30mm carb at this point. Later on when i´ll move to 535cc cylinder, i will buy a Mikuni TM32.
Are anyone of you familiar with the "OKO" brand 30mm flat slide carb? Seems to be very cheap as a temporary solution...
BR.
Andy
That one will work ok, and is popular with scooter owners, but you have to be sure you can get the jets you need.
Sometimes these "knock-off" carburetor clones don't take the same jets as a Keihin or Mikuni, so you need to check that out
