Author Topic: C5 - Intermittent Fuse Blowing  (Read 5452 times)
prof_stack
Reply #15 on: November 06, 2010, 02:32:25 pm
When my dealer installed the first larger headlamp on the demo C5 it blew a fuse as soon as the key was turned to on.  A wire inside was pinched.  Glad it happened before they installed the larger headlamp in my C5.
Was your problem the same or was it with the original headlamp?
raycopper
Reply #16 on: November 06, 2010, 04:29:25 pm
Original headlamp, but that is 7" in the UK. My problem was a small grey wire that could easily have been routed through the centre of the loom, was taking the weight of the loom and had been rubbed through over 2500 miles by steering movement
Ray
2010 C5 - Red
