I have the exact setup that you have and what ace suggested with the stock needle all the way up/needle clip on the lowest setting. Ace: I get the 1/3 hipcup every now and then. If I let her warm a wee bit longer or take off gently and nurse it bit it seems to be done and over it after about 1/8 to 1/4 miles down the road. Its never been any real problem but I can assume if I do as you suggested then the occssional hipcup/carb thingee should evaporate.
Green Machine,
The 1/3-throttle hiccup is definitely needle jet territory.
If it is a very mnor hiccup, and goes away after warm-up, it is probably ok.
However, it might get worse in cold weather, because the denser air causes the carb to run leaner.
You might try a P0 needle jet, and see how it goes for you.
If it's too rich in the summer with that, then just use the P0 needle jet for your winter jetting, and go back to the O8 needle jet for hot summer.
It's not unusual at all to need different jetting in winter and summer.
The needle jet is a critical jet, because it controls the mixture in the throttle range that is used the most in normal everyday type riding.
