Mt ride 2
33 Guests, 7 Users (1 Hidden)
ace.cafe, oTTo, cstorckiii, gizzo, MarkF, Gesewa
May 04, 2016, 12:28:17 pm
Author Topic: primary cover on classic engine  (Read 1895 times)
birdmove
« on: January 14, 2008, 08:26:42 pm »
    Noticed my primary cover has a bit of a leak and was going to tighten the bolts. But it looks like its held in place by one large bolt? My RE manual actually seems to show its held in place by a bunch of bolts.
    jon
Jon in Keaau, Hawaii
deejay
Re: primary cover on classic engine
« Reply #1 on: January 14, 2008, 09:52:38 pm »
    jon
one bolt. mine tends to weap a bit as well. the primary cover on the electra has a bunch of bolts.
mrunderhill1975a
« Reply #2 on: January 14, 2008, 09:58:21 pm »
One bolt, however, don't be tempted to tighten that bolt too much, it's aluminum and will strip the threads faster than bob's you uncle.  I just let mine weep ever so slightly.
« Reply #3 on: January 15, 2008, 12:04:44 am »
Not to worry...   you'll be in there soon enuff at your 500 mile service to check primary tension. Make sure seal is clean and mating surface is clean as well. any little debris can cause this.
- Mike
dogbone
« Reply #4 on: January 15, 2008, 09:11:51 am »
I have put a layer of wheel bearing grease on the rubber gasket, It stopped the leak. I use type F atf
99 Enfield Bullet 535
deejay
« Reply #5 on: January 15, 2008, 09:50:50 am »
I like this idea, thanks
fredgold52
  • Macomb, IL Flatlands Rule
« Reply #6 on: January 19, 2008, 06:05:59 am »
For what it's worth, we old 2 stroke Vespa scooter mechanics use wheel bearing greese instead of gasket sealer on every joint in the engine, including the intake.  It works very well and make disassembly very easy.  I resisted the idea at first and so was late coming to it, but now it's all I use.
