I suspect our brethren from accross the pond will see this gorgeous ride before we do and I think we will eventually see it in the US. Here's the list of the specs, as well as a link to an additional 40 photos at the end of the list:
Engine and TransmissionEngine type: 2 cylinders, 4-stroke, Inline
Displacement: 773 cc (47.23 cubic inches)
Bore × stroke: 3.03 inch × 3.27 inch (undersquare - longstroke)
Throttle: Cable operated
Valves Valve train: SOHC, variable
Valves per cylinder: 4
Fuel and ignitionSparks per cylinder: 1
Fuel supply system: Fuel injection
Ignition type: Digital CDI
Funnel diameter: 1.34 inch
Compression: 8.4:1
Engine mounting: Transverse
Lubrication system: Wet sump
Gear box: Manual
Clutch: Wet, multiple discs, cable operated
Starter: Electric
DimensionsLength: 85.8 inch
Width: 31.1 inch
Height: 42.3 inch
Wheel base: 57.7 inch
Trail: 4.3 inch
Ground clearance: 4.92 inch
Seat height: 31.1 inch
Curb weight: 476.2 lbs
(Papa: Not a Lightweight after she's full of fluids but still less than a Hinckley Bonneville.)Chassis and Suspension Frame type: Steel, Double cradle frame
Front Suspension: Cartridge
Suspension travel: 5.12 inch
Fork angle: 27°
Brake: Single Disk, Ø11.81 inch
Tire: 100 / 90 R19
Rear Suspension: Twin shock, Swingarm
Suspension travel: 4.13 inch
Brake: Drum, Ø6.3 inch
Tire: 130 / 80 R18
OtherABS available: No
Fuel capacity: 3.7 gals
Number of riders: 2 persons
http://www.mbike.com/kawasaki/w800/2011
