Author Topic: LED Failures  (Read 4096 times)
DavidMeermans
Reply #15 on: November 22, 2010, 12:26:23 am
I checked the voltage to the LEDs (gray wire from right handlebar switch) using an oscilloscope and it runs about 14 volts with a short spike (about 1 more volt, I think--did not write it down) at each sparkplug firing.  On http://reuk.co.uk, I found a circuit for a voltage regulator using an LM2940T-12 and a 100uF capacitor.  I assembled the regulator on a test board today and it completely smooths the voltage at 12 volts.
Since the LEDs are pretty cheap, they likely have only a resistor to limit the current and so depend upon steady supply voltage.  Two to three extra volts will let them draw too much current, which will wreck them.  I will see if the regulator helps as I will replace all the LEDs.
I will install it next week after I receive some Hitachi connectors to let me add it without cutting wires.
Reply #16 on: November 22, 2010, 07:34:35 am
Bookmarked for DavidMeermans update  ;) ;)
Btw, this voltage regulator you mention,,is it a thermal resistor ?
single
Reply #17 on: November 22, 2010, 02:27:35 pm
Very good,Geirskogul.I actually spelled that from (alleged) memory.Thanx for mentioning Oldsmobile.G.M. forgets,but I won't.And,Dan,my cowl lights are still glaring defiantly.Love the bluish look.
Reply #18 on: November 24, 2010, 01:10:23 am
Fellas, are there any L.E.D.s that survive in elevated temperature enviroments ?
It would be nice to have an LED pilot lamp for use in my H4 halogen headlamp .
clamp
Reply #19 on: November 24, 2010, 03:21:00 pm
yeah fit some LED's
  Im not --I enjoy the simplicity of the simple bike I bought, becaue a simple bike is what I wanted .
    The last thing I want Is a fuel injected common rail  car or bike with leds or anything.
    Points and condenser  please,,--Oh and light bulbs.
   Geeeez go by a Hyabusa.
I would never be a member of a cub that would have me as a member
DavidMeermans
Reply #20 on: November 25, 2010, 07:43:18 pm
No, it is a true regulator.  I have attached the datasheet.  This one is designed to operate within 1/2 volt of the supply voltage.
Happy T-day,
Dave M
r80rt
  • C5 Pilot
Reply #21 on: November 25, 2010, 08:18:25 pm
« Last Edit: November 26, 2010, 02:04:56 pm by r80rt »
Iron Butt Association
Reply #22 on: November 25, 2010, 09:54:46 pm
yeah fit some LED's
 In my case the idea is light with low current draw= greater battery reserve in order to limp home when the ghost of Lucas in league with Murphy conspire to eat my voltage regulator/rectifier,,at night, in the rain, on the trail,, 20 miles from nowhere  ;D
That and the Hyabusa would make a poor choice for of road riding.
r80rt
  • C5 Pilot
Reply #23 on: November 26, 2010, 02:03:59 pm
"Dan,my cowl lights are still glaring defiantly.Love the bluish look."
Glad you like them, I hope they will last you a very long time.
Reply #24 on: November 30, 2010, 02:45:45 am
Happy T-day,
Dave M
Cheers Mate,
