I havent gotten around to it yet, but I was going ot stich a sock in there and then slice around the neck with a blade and neatly remove it all.
When the paint is like this, it does NOT seal well. If you fill your tank all the way up and then put it on the side stand, it leaks gas al over your nice hot engine.
After you fill; up, use the center stand!
I'm sure I have a few chunks of paint hanging out in my gas tank.. kind of sucks! Anyone know if the fuel filter is easy to get to?
