They are young, fragile, vulnerable, and need the utmost protection
Totally agree! under 60 you're young and fragile and vulnerable, and then, over 70 you're old and fragile and vulnerable
This must be the most courteous and respectful bike forum I ever came across .
And a very helpful one, of course.
It seems to me it was more throttle position - than rpm, though I'm not absolutely sure. That's why I thought "carbs" or fuel delivery. Can't look around the gastank - without a periscope. ...Reminds me of a similar experience with an outrageous Confederate. The issue there : the peeling coating of the carbonfibre tank was clogging the fuelfilter off and on.
What happens during a topspeed run, I guess is NOT max rmp, NOT max heat, but max fuel and air flow. Anyway, will make a dealer appointment, and check some more.
Thanks a bunch
