Liz...
14 Guests, 2 Users
wildbill, kodai
May 04, 2016, 11:47:48 pm
Author Topic: Carb Adjustment Question  (Read 2782 times)
fredgold52
  • Macomb, IL Flatlands Rule
« on: January 11, 2008, 03:55:26 pm »
Does the low speed adjustment (not idle but mixture) screw meter air or gas?  When you turn the screw counter-clockwise, does it get richer or leaner?
Thanks,
Fred
Vince
Re: Carb Adjustment Question
« Reply #1 on: January 11, 2008, 05:13:33 pm »
It meters air. Unscrewing (counter clockwise) will let in more air. This leans out the idle mixture. Screw it in (clockwise) to cut off air. This will richen the mixture.
fredgold52
« Reply #2 on: January 11, 2008, 05:16:15 pm »
Thanks Vince.  I'm glad I asked because that's just opposit of how my scooter carb works.  Now all I have to do is keep it straight in whats left of my mind about which bike I'm working on.
« Reply #3 on: January 11, 2008, 05:18:37 pm »
http://www.iwt.com.au/mikunicarb.htm
Might prove useful as Mikcarb is the Indian (built under licence) Mikuni!
« Last Edit: January 11, 2008, 05:20:18 pm by LotusSevenMan »
luoma
« Reply #4 on: January 11, 2008, 06:58:41 pm »
Works the same way on the CMW flat-slide carb. I was used to the old type fuel mixture and screwed it up a bit. My mechanic buddy educated me. It was the last step I had to take to really dial in my bike. Runs almost too perfect now
« Reply #5 on: January 12, 2008, 04:55:11 pm »
luoma.
Oh no!                        Dangerous time!!!!!!
I usually find that just when I get any mechanical piece of equipment about perfect it goes 'bang'. All the while there are tiny outstanding niggles/things to do it's OK.
All perfect? As the song says "There may be trouble ahead........"
Hope I it's just me and not S*ds Law in action eh?
luoma
« Reply #6 on: January 12, 2008, 06:50:08 pm »
Worries me too. Especially now that winter has set in and I will be wanting to tinker more often than ride. Guess I'll just have to invent some things to do to it, like new tires, or heavy duty clutch springs.
grumpyed
« Reply #7 on: January 26, 2008, 06:13:09 am »
Easy way to tell at a glance is if the screw is nearest the engine it is fuel adjust.If its back by the filter side its an air bleed.
