The Green Street Bullet
August 31, 2015, 03:18:37 pm
Author Topic: EFI: Lean then Rich  (Read 3165 times)
Mance
EFI: Lean then Rich
« on: September 23, 2010, 02:36:44 pm »
Hi Fellas,
I'm a new RE owner, and this is my first post.  I'm glad to be a part of the club, and I love the bike.
I have a 2009 Military (C5 / UCE / EFI).  The bike has approximately 4300 miles on it, and I've only had a few minor problems: bad battery (twice), replaced chain at 4000 miles, and now I'm having a performance issue.
The bike misfires and backfires.   Sometimes it is REALLY bad.  I worried that I wouldn't make it to my house 2 miles away a couple of days ago.  Sometimes it doesn't happen at all.  I took an hour ride yesterday, wound out the bike and it performed perfectly.  Today it is working perfectly.
Related Notes:
1) The exhaust pipe has heavy bluing.  (Maybe the engine is running lean?)
2) I can't see a substantial difference with temperature, but the problems only started this summer, and the weather in Texas is always warm.
3) In the past couple of days, when bike has worked well, there is a strong smell of gasoline.  That is new and unusual.  Smells like it is running rich.
Here are the possibilities I can think of:
1) One of the sensors used for EFI is going bad.
2) There is a vacuum leak either in air intake or with the exhaust that gets seeled up when the engine heats up.
3) The bike just takes a while to warm up, and it is going to misfire / backfire until it does.  But that isn't normal for EFI?  Correct?  And this didn't start until around 3000 miles.
Any ideas?  What could make the system suddenly go from running lean to running rich?  Or could the symptoms be caused by something else?
Thanks
Mance
Re: EFI: Lean then Rich
« Reply #1 on: September 23, 2010, 03:20:05 pm »
Hi Fellas,
I'm a new RE owner, and this is my first post.  I'm glad to be a part of the club, and I love the bike.  I have a 2009 Military (C5 / UCE / EFI).  The bike has approximately 4300 miles on it, and I've only had a few minor problems: bad battery (twice), replaced chain at 4000 miles, and now I'm having a performance issue.
Mance:
Welcome.  The engine can backfire and misfire due to many reasons, as you have pointed out - including problems with spark, fuel/air supply, or compression.
Start by checking the simplest things.  Spark plug - is it worn out or ok ? Put a new spark plug and see if it improves.  The intermittent occurance suggests that there may be a loose electric connection.  Is the spark plug cable connected firmly into the spark plug and to ignition coil ?  Look for any air leaks in intake manifold.  A dirty or clogged fuel injector may also contribute to misfire or backfire.
The bike runs lean by default.  I guess that if any EFI sensor was bad, the Malfunction Indicator Light would come on.
« Last Edit: September 23, 2010, 03:44:52 pm by singhg5 »
Mance
« Reply #2 on: September 23, 2010, 03:51:39 pm »
Thanks for the note.
Yes, I forgot to mention that I changed the spark plug.  Replaced with stock equivalent.  I don't have any experience looking at plugs to tell if the bike is running lean or rich, so I can't say much about how the old plug looked.
I wondered about the fuel intejector.   At its worst, it felt like the fuel line was clogged somewhere.  Almost impossible to keep the bike running.  However, a storm had just passed through, and the temp dropped 20 degrees.  No idea how / if that affects EFI on this bike.
The spark plug cable is connected firmly at the plug, but I haven't checked it at the coil.  Will do.
I'm not a mechanic, but I want to learn how to maintain this bike on my own.  Outside of visually inspecting the air intake, is there something else I should do to check for air leaks?
Mance
Mance
« Reply #3 on: September 23, 2010, 10:05:09 pm »
Whoa!! Major problem.  The reason I started the bike smells like it is burning very rich is that the fuel tank is actually leaking gas!  Near the rear bolts on the left side where there is a welded seam, gas is oozing from the tank.
I assume that something from the tank actually broke lose and made it into the gas line a few days back when the engine was running at its worst.  The performance of the engine has been great for the past two days.
I guess this calls for a trip to the dealer in the morning.
Mance
prof_stack
« Reply #4 on: September 23, 2010, 10:55:48 pm »
Mance
Yes, it does.  Let us know how it goes.
« Reply #5 on: September 23, 2010, 11:01:58 pm »
The electrode of too rich spark plug will turn black due to unburnt carbon deposits and too lean spark plug electrode will be whitish.
You found the leak from the tank.  Sure it is time to see the dealer.
Mance
« Reply #6 on: September 23, 2010, 11:44:10 pm »
Will do.  After doing a little more research, it looks like a few others have had problems with rust inside the tank leading to pinhole leaks.  But most of those are on older bikes.
Rust would probably explain the sporadic misfires and poor performance of the engine, but this bike is less than a year old, so I am surprised.  I don't always keep the tank full, but I ride it daily and fill up frequently.
If it turns out to be rust in the tank (and it sure looks like a pinhole leak at the welding seam), then we can add another possible cause to the standard list of misfire / backfire / performance problems.
Mance
« Reply #7 on: September 24, 2010, 09:49:10 am »
Here is a reference picture of what a spark plug looks like under different conditions -
Mance
« Reply #8 on: September 24, 2010, 09:59:58 am »
Wow.  That is a great reference.  Thanks.  It will get printed and put on the garage wall.
I took the bike to the dealer today.  He doesn't believe there is rust in the tank, but rather believes that the joint where the tank gets bolted to the chassis just isn't holding up from the vibrations.  After the tank is replaced, he plans to put some kind of dampener around the bolt.
Regarding the sporadic performance, he has heard some people speculate that the catalytic converter isn't getting hot enough on short trips.  As a result, gunk builds up and causes problems.  After I ran the bike hard for 30 minutes earlier this week, the symptoms did go away.   On average, I ride the bike only 5 minutes at a time, and the engine never really gets that hot.  So maybe it is the CC.
More to come.
Mance
Vince
« Reply #9 on: September 24, 2010, 10:42:08 am »
     Riding the bike 5 minutes at a time is the cause of most of your issues, including the battery. It takes about 1/2 hour of normal running to recharge a normal battery from one normal starting attempt. Your riding habits run the battery down. The ignition system runs off the battery. The charging system charges the battery. Low battery=weak ignition/injection=poor running="defective battery". Even with F.I. you will not get proper burn/combustion until the engine is warm.
     You should change your riding habits. Ride more and longer.
WillW
« Reply #10 on: September 24, 2010, 11:05:12 am »
"Ride more and longer"
music to my ears.......   :D
1 Thump
« Reply #11 on: September 24, 2010, 11:42:00 am »
I like that .
1Blackwolf1
« Reply #12 on: September 24, 2010, 01:39:38 pm »
  Should also install a battery tender to keep it charged up if you can't ride it for long distances.  Cost is generally less than 30 bucks and will eliminate lots of problems.
Will Morrison
2007 500 Military
2000 Kawasaki Drifter 1500
2000 Victory V92SC
Many, many other toys.
The garage is full.
prof_stack
« Reply #13 on: September 26, 2010, 11:47:14 pm »
+1
The Battery Tender will pay for itself after one year.  I think all new Enfields come with a connector installed.  Mine did and it is on the bike in the garage all the time.
Geirskogul
« Reply #14 on: September 27, 2010, 03:27:26 am »
No, the connector is a dealer special.  Mine didn't have one.
