Oh dear, I think I have won the slack challenge. Just measured mine and its more then 50mm. Although the chain tensioner is shot on mine but I doubt if it can result in so much of play.
I think the best and more accurate way would be to measure the slack with the LH side chamber + clutch off and measure the slack by holding the clutch shaft and the front chain sprocket.
Things I am ruling out on mine
Cushion rubber- as mine was just changed recently
Chain- is adjusted to the minimum slack possible
I removed the Rh chamber and took off the drive chain. Shifted in gear and moved the drive sprocket. The slack was still there.
So I am more inclined to believe that its in the gearbox and very less chance of shot chain tensioner to cause enough slack to transfer it to the gears.
Singh JI, I think we all should put the slack measurements with the mileage of the bike for a clearer picture.
Singh G5 52mm +10,000miles
SSR C5 50mm 9,800miles
Will 42.5mm
Chris G5 35mm
r80rt 38mm
Andy 48mm
