And its not just one mechanic. Let me run you through some problems I've had with some of the best mechanics here in Mumbai INCLUDING the authorised service center. I say besy because they have a huge customer base and are quite experienced in just Bullets.
Mech 1: Gone for a regular service. Changes primary oil, forgets a washer inside, washer goes into alternator coil/magnet shorting it completely.
Mech 2 (authorised service center): Head Gasket replacement. Changed and returned back home. Seen a lot of oil leaking from the head and I had no idea of the exact source. I investigated and found that the head bolts weren't tightened at all.
Mech 3: Regular service. Primary oil changed. Primary casing nut left loose, causing oil to leak.
Mech 4: Bike was misfiring and had a lot of clatter. Mech said the complete timing assembly has to be checked and the pushrods have to be replaced. Heck instead what I noticed is that after sorting out the electrical misfire, the clatter has significantly reduced. So I wonder....
Mech 5:
I've shown the current electrical misfiring problem and the past manifold leak misfire to all of the above, and none of them could sort it out.
The manifold misfire was not caught by ANYONE. I suffered with that problem for around 9-10 months. A fellow member on Team-BHP.com advised me to check it. I bought a replacement and changed it myself. Worked like crazy after that.
I've had the electrical misfire twice. Once I had it for MORE than 1.5 years. Every mech did the usual - clean spark plug, carb, check air filter, etc. - no difference. Eventually I was frustrated, sat down with the bike for 30mins - thought MAYBE its the front brake switch getting short. Removed it and was stumped when it ran without a gliitch, misfire, or backfire. ** I'm still confused on how a brake switch can cause a misfire **
About the recent electrical misfire - even the mech I recently gave it too, sorted out the problem ONLY because I was assisting him while he worked on the bike - else he was going to change the regulator also.
