Winter Testing!
37 Guests, 3 Users
no bs, Guaire, MeVoCGT
February 10, 2016, 02:05:06 pm
Author Topic: question about delay switch for Electra  (Read 1354 times)
scoTTy
« on: January 10, 2008, 05:25:02 pm »
ok.. the blue and white wires are self explanatory plug and play.
Now the other 2 wires that are coded green going in the relay and out with the white connector and the black connector , they too,  are self explanatory... they go to the switch that connects to the side stand..
However I took the switch off the side stand because the wires got cut in shreds from something, the side stand , the center stands, rodents, I don't know.. .
My question is __do I connect the two green wires together.. the white male connector going to the black female connector to make a closed loop__or do I just tape them off and leave them open, of course using tape to seal the ends__or will I have to put the switch back on the side stand?
thanks in advance
Vince
Re: question about delay switch for Electra
« Reply #1 on: January 10, 2008, 06:18:40 pm »
I'm not sure. I haven't run into this one yet. Just leave them unplugged. If the engine starts you are OK. If that does not work then hook them together. One way or the other should work. If not, let me know and I'll do some hands on research.
scoTTy
« Reply #2 on: January 10, 2008, 07:39:24 pm »
i'll post pictures of the RE electric meltdown later not tonight..   ;)
 thanks Vince..   :)
