G5 Classic
August 03, 2015, 09:14:57 am
Author Topic: Sprocket change or Gozilla vs Maturin  (Read 1857 times)
BRADEY
Re: Sprocket change or Gozilla vs Maturin
« Reply #15 on: September 07, 2010, 11:24:37 pm »
Royal Enfield Dealerships are provided with special tool (a wrench that looks exactly like your spark plugh wrench in shape, only its bigger). I recently had mine opened and it was pretty easy. However as your dealer said, sometimes these things load up more, as in the case of my brake fluid reservoir screws. One of them got stripped in the process, no matter what "trick" I tried on it. ;D
Maturin
  • My Precious
« Reply #16 on: September 08, 2010, 04:12:39 am »
Good to hear that this struggle is over.  What size sprocket did you put in your bike ?  How is the ride ?
I changed to the Classicīs 18-tooth-sprocket. I wonder why itīs not standard in the G5, itīs so much better!
The ratio now fits very well to the german speed limit steps that are mostly 30/50/80/100 km/h. Acceleration generally has improved because the former dispensable 1st gear puts the bike forward now instead of only causing noise. Even with two on board you donīt need the clutch much. I dinīt tested full throttle yet - always had a truck ahead ::) - maybe thereīs a little plus in top speed.
A recommendation, but: beware of Gozilla!  ;D
2010 G5
Walter Röhrl
t120rbullet
« Reply #17 on: September 08, 2010, 05:49:39 am »
I wondered that myself. There doesn't seem to be a downside.
CJ
