Loving it!
April 28, 2016, 04:53:45 pm
Author Topic: Sprocket change or Gozilla vs Maturin  (Read 2116 times)
Maturin
  • My Precious
« on: September 06, 2010, 02:21:02 pm »
Just got out of my garage after a 2 hours fight with the front sprocket. It won, I have to admit defeat on the first day.
The way to it was easy, although it takes some time to remove kickstart, footrest, electric cable and all the srews. But when I was through I saw a gigantic nut: a size 46 mm-nut, secured with a sheet. I called it Godzilla and after I organized a 46-nut I tried to move it by hand, later with a impact wrench and even later with an electric impact wrench.  >:( >:( >:(
When I think about people in India I usually picture someone with a brownish tan, a little smaller than myself. I really have to rethink that! The mechanic whoīs job it is to fix the Godzillas must be 2m and 150 kg at least!
The monster didnīt move a single mm. Is there a trick? Iīm just loading the electric wrench tio get full power, but itīs a riddle for me. I guess I oversee something. Anybody with similar experience?
2010 G5
Walter Röhrl
Re: Sprocket change or Gozilla vs Maturin
« Reply #1 on: September 06, 2010, 02:32:07 pm »
It's not a left hand thread is it?
« Reply #2 on: September 06, 2010, 04:05:52 pm »
If there are no major rubber seals in the area a little heat from a torch and a few shapr whacks with a hammer will loosen many stuck nuts.  As mentioned, check which direction the threads run.
« Reply #3 on: September 06, 2010, 04:51:55 pm »
If it's on the right side of the bike, it could very well be a left-hand thread.
« Last Edit: September 06, 2010, 04:55:47 pm by ace.cafe »
Vitalc
« Reply #4 on: September 06, 2010, 05:11:48 pm »
The manual doesn't mention anything special. Manual says M35 nut ?? Torque should be 80 Nm, which is pretty modest.
Gozilla stressed? nervous? cramped?   Oh dear... :(
I remember reading a few threads about changing FD sprockets, so some people must have managed to relax Gozilla in the past ??
t120rbullet
« Reply #5 on: September 06, 2010, 06:28:10 pm »
No, it's not a left handed nut.
Did you fold the tab washer back? And leave the chain on?
CJ
« Reply #6 on: September 06, 2010, 06:37:25 pm »
What CJ said .... he's been there, done that ...... so have I - and it ain't THAT tight ....
« Reply #7 on: September 06, 2010, 07:38:05 pm »
There is a LOCK TAB washer behind the sprocket nut.  Use a flat screw driver to push the tab off the surface of the nut - i.e. UNLOCK it.  Then you will be able to turn the nut.
« Reply #8 on: September 06, 2010, 07:43:58 pm »
Try this way - as shown in the picture
Maturin
  • My Precious
« Reply #9 on: September 07, 2010, 04:49:44 pm »
Gozilla has lost! Finally!
Itīs not a left hand threat, itīs clockwise as usual. The electric impact wrench failed - after all 135 Nm - and after I twisted the brake pedal holder trying to get torque on the long ratched I gave up, called the cavallary and put everything together again.
At my dealerīs the friendly and compassionate foreman first hammered the brake holder back again and THEN...finished off Godzilla with an air-pressure impact wrench with 600 Nm within 1 1/2 seconds. Hehe. It got what it deserved.
Sometimes, as he told me, due to temperature, threatīs distortion and bad luck its possible that the load necessary to move the big nut rises up from originally 150 Nm up to 500 Nm - what is certainly to much for anyone who isnīt trained in martial arts. And too much for brake pedals. But as I got  annoyed with the problem I lost the ability to see the situation in general - and thatīs the point when the risk comes up to destroy something. I should have known better, pure luck I fucked up something that was easy to fix.
The result of this epic struggle: a correct gear ratio, comfortable to drive and well fitting to german speed limits. Suceeded at last!
2010 G5
Walter Röhrl
« Reply #10 on: September 07, 2010, 04:52:37 pm »
Glad you got it!
« Reply #11 on: September 07, 2010, 06:39:44 pm »
I've used 6' levers to remove rusted axle nuts on the back of a VW bug.  They make scary noises when they're that tight.  Congrats on getting it sorted.
Vitalc
« Reply #12 on: September 07, 2010, 08:38:06 pm »
Scotty,
how about your Gozilla ?  Got the better of it too?
« Reply #13 on: September 07, 2010, 09:48:54 pm »
Yea man , I remember those days.Pipe wrench, cheeter pipe :D  Rusted floor boards, broken/ rusted  shock towers, rusted heat exchangers every year or two. 13 teenagers in it at one time. Man I miss my old Bugs. They were great cars, nice and simple.
« Reply #14 on: September 07, 2010, 11:13:51 pm »
Good to hear that this struggle is over.  What size sprocket did you put in your bike ?  How is the ride ?
