Heh, I just adjusted the chain for the very first time, at 300 miles.
Who thought up having snails adjust your chain?
Castle nut - 24mm or 15/16 inch (I used this socket)
Spindle nut - 30mm or 1 3/16 inch (ditto)
Anchor nut - 19mm (
corrected from 18mm)
Brake rod nut - 13mm
I should have marked the snail settings with a Sharpie before I started. Getting the wheel aligned was all about visual settings from behind the bike. If there is a more precise way, please broadcast it.
But it all went back together and the chain is tighter, the brake is adjusted back to spec, and the wheel turns freely with no binding, so I have to say it was a success.
I also changed the oil, but that is for a different thread.
