Mike's 2003 ES 500
May 02, 2016, 07:33:28 am
Author Topic: MPG Survery  (Read 2219 times)
jjoe256
MPG Survery
« on: August 30, 2010, 02:12:50 pm »
     I'm trying to get a handle on this. People have mentioned it piecemeal, so let's compile it. My 2009 G-5 never got better than low 60's even during easy breakin, but the C-5's that I know of have done much better, so  here's a survey to find out the ranges of the two models: G-5 vs. C-5:
jjoe256
Re: MPG Survery
« Reply #1 on: August 30, 2010, 02:31:17 pm »
I'll add top speed to this. Best mine will do is 82 indicated, tucked in and level.
clubman
Re: MPG Survery
« Reply #2 on: August 30, 2010, 04:22:42 pm »
OK, I think this will be really interesting but let's also state US or imperial gallon for accuracy as this is a worldwide forum in practice.
So my 2009 G5 Clubman (with open pipe) has done 80 mpg worst and 92 mpg best, imperial gallons. Average is 85mpg; I usually travel between 60 and 70 indicated and top speed has been 85 indicated. I have never used full throttle.
jjoe256
Re: MPG Survery
« Reply #3 on: August 30, 2010, 05:22:38 pm »
Right you are. US measure!
jjoe256
Re: MPG Survery
« Reply #4 on: August 30, 2010, 05:27:35 pm »
Should also add 87 octane (r+m/2), throttle pegged. I might try 92 (r+m/2) and see what happens, both speed and mpg.
Re: MPG Survery
« Reply #5 on: August 30, 2010, 06:20:06 pm »
Good point.  I used 92 octane, which may or may not change things.  What about tire pressure?  The manual says 18/20psi for f/r.  That seems low.  What are other riders setting the psi at?
Also, isn't the G5 gearing differently than the C5?
« Last Edit: August 30, 2010, 07:02:02 pm by prof_stack »
Re: MPG Survery
« Reply #6 on: August 30, 2010, 07:14:28 pm »
The tire pressures in the manual must be a mis print, it's too low. I run 27psi in front and 29 in the rear on my C5. I get 80-85 mpg and I have no idea what the top speed is, and I doubt that I'll ever know. :D
Re: MPG Survery
« Reply #7 on: August 30, 2010, 07:36:21 pm »
 The plate on the front down tube states 24 psi front, 32 psi rear. I' m still experimenting with the 19" front wheel. But thats my starting point. I've noticed after fill up, the tank lasts forever :D
Re: MPG Survery
« Reply #8 on: August 31, 2010, 02:35:18 am »
I average 85 mpg  -  UK gallon. Worst was 79 (lot of short rides) best 89. I rarely exceed 60mph, but occasionally 70-75 for short stretches. Changing from stock exhaust to Goldie made no difference to mpg.
Tyre pressures  -  27 front, 29 rear, on Avon Road Riders.
JohnofDelph
Re: MPG Survery
« Reply #9 on: August 31, 2010, 02:42:07 am »
You may not believe these figures, but they're accurate! I ride mostly between 50 and 65 mph and accelerate briskly but smoothly. Riding like this, I have achieved a worst figure of 82 mpg (UK gallons) and a best of 97! Riding to and from work gives 86 and longer runs about 94. You can check my fuelling on www.fuelly.com and it shows in US gallons.Fuelly is a great site if you want to monitor your fuel consumption - lets get more Enfields on it! :)
Re: MPG Survery
« Reply #10 on: August 31, 2010, 10:04:41 am »
My G5 consistently gives 70 mpg (US gallon), that would be equivalent to 83 mpg (British gallon).  I ride small town roads at speeds between 30 - 60 mph, so it includes traffic light stops and slow traffic.  I add Star Tron fuel treatment to regular gas.  It keeps the lines clean, prevents fuel degradation, and easy start in cold weather.
Addition of Star Tron does not affect mileage.  Premium gas makes no difference in mileage either.  Premium gas does offer easy start up in winter.
TheFatMan
  • The Fat Man's home on the lake
Re: MPG Survery
« Reply #11 on: September 01, 2010, 03:04:45 pm »
My C5 is over the magic 600 mile break in now, so I suspect it will improve some (?).  I average about 70 mpg with mine in mixed around town (stop and go) traffic and back country roads. I use premium because there is one station locally that has "no ethanol" gas, but only in premium.  Also, rear tire pressure is 28 or so psi and front is 25 or so.
Maturin
  • My Precious
Re: MPG Survery
« Reply #12 on: September 01, 2010, 05:22:50 pm »
From the first kilometer on my precious developed only modest thirst. With tire pressure of 30/35 PSI it consumes 2,9 - 3,2 L, that is 87-97 mpg (imperial). Top Speed is 140 km/h or 87 mph on a flat road without wind.
@ jjoe: gearing is almost the same, the G5 has 19´wheel and 17-tooth-sprocket, the C5 has 18´ and 18 tooth. The difference is within the the slip of your tire.
2010 G5
Walter Röhrl
jjoe256
Re: MPG Survery
« Reply #13 on: September 01, 2010, 05:34:04 pm »
I talked to a Shell distributor today who said all brands and grades of gas-except marinas-in Washington State are mandated to have <10%ethanol content, so non-ethanol gas is not an option. Here's a link for all states:
http://www.fuel-testers.com/state_guide_ethanol_laws.html
Maturin
  • My Precious
Re: MPG Survery
« Reply #14 on: September 01, 2010, 05:39:10 pm »
Living on another continent I´m not affected but..is this good or bad?
2010 G5
Walter Röhrl
