Reply #3 on: August 26, 2010, 12:48:04 pm
I noticed that when I had mine apart to change the springs. Just two little tack welds is all that holds the top on. Thanks for the heads up. (edit) Hey wait a minute, that is the threaded part isn't it? The tack welds I'm referring to are still there, holding the threaded boss below the eye. It looks to me as though the threads pulled out
« Last Edit: August 26, 2010, 04:58:29 pm by cyrusb »
Logged
