April 29, 2016, 10:56:24 am
Author Topic: G-5 Oil change Enigma  (Read 2708 times)
Re: G-5 Oil change Enigma
« Reply #15 on: August 23, 2010, 03:45:37 pm »
Do the new UCE bikes come with the improved oil filter device, the same one advertised in the Nfield catalog?
« Reply #16 on: August 23, 2010, 04:45:34 pm »
Your bike should come with one.
louis 911
« Reply #17 on: August 25, 2010, 02:04:18 am »
Possible to see photos of the new filter  :)
« Last Edit: August 25, 2010, 02:08:55 am by louis 911 »
« Reply #18 on: August 25, 2010, 09:29:33 am »
Only the oil filter cap is improved.  Everything else is the same.  Here is the link to its picture -
      http://www.enfieldmotorcycles.com/forum/index.php/topic,8199.0.html
« Last Edit: August 25, 2010, 09:33:10 am by singhg5 »
meilaushi
« Reply #19 on: September 11, 2010, 07:44:15 am »
Matt, my dealer, sez that when I bring the bike (G-5 Dlx) in for its 500 mile checkover and oil change, he's going to replace the old hellacious cover with the new easy one if necessary (i.e., it hasn't a new one on already as might seem to be the case from the other post noted above).  And I get to watch what happens so I'll know when I'm taking care of things in my own garage after that. :)
Ralph Meyer
2010 BMW F800ST
louis 911
« Reply #20 on: September 12, 2010, 10:28:28 am »
Do not forget that a quantity of oil  rest in the primary crankcase.
« Last Edit: September 12, 2010, 10:31:41 am by louis 911 »
