What's the secret?? I have just completed my second oil & filter change on my G5. Twice now I have overfilled and have had to drain excess oil and am having a difficult time getting the level just right.
I have followed the instructions in the manual. Engine oil was warm, gave the bike 1 hour to drain. Tilted the bike in an attempt to drain ALL the dirty oil out, soaked the new oil filter, etc.
After adding 2 quarts of oil. The level looked correct in the sight window.This would indicate I had not gotten all dirty oil out after all since the manual states the the crankcase holds 2.75 Liter/2.9 quart. I started the bike and let it run for a few minutes. After stopping the engine I let the bike sit for 20 minutes to allow the oil collect in the crankcase. The level dropped down to the bottom of the sight window and never went back up to where I had seen it before starting the bike. I added a bit more oil . Again the level looked good, so I went on a short ride.When I returned the level was too high. I let the bike cool down for 90 minutes according to the sight window the level was still too high. I then drained a small amount of oil, and the level dropped down to the bottom of the sight window again.
Can anybody tell me what is going on? I have done many oil changes on all my other bikes, but the G5 seems a bit tricky by comparison.
Also, does the MIL indicate oil pressure trouble?
How much oil came out of your engine ? What grade oil did you add ?
By all accounts, it takes only 1.8 Litres of oil ( 2 quarts is more than enough).
As far as not seeing the oil in window is concerned -
if the bike is standing at an angle, tilted even slightly to the left, the oil is not visible in the window. If it is not visible and you have added enough oil, slightly tip the bike to the right just to check if oil is visible in the window. Then straighten it up and check again.
Also, it takes only about 200-300 ML of oil to reach from Lower to Upper Level mark in the window. A small difference in the volume of oil is magnified and appears to be full or empty !
I don't think MIL will indicate oil pressure, even if there was a problem. MIL only indicates malfunction in electronic sensors or circuit - such as Throttle Position Sensor, Manifold Air Pressure, Engine Oil temperature circuit, Oxygen sensor, Rollover sensor, Injector circuit, Ignition coil, Fuel pump, Crankshaft position circuit.
Check out this link -
http://www.enfieldmotorcycles.com/forum/index.php/topic,5148.0.html
