More like 1.75-2 quarts, I can't remember because I fill mine to the bottom of the dip stick, then run at idle for a minute or two, shut off then check oil again . add if necessary to about half up the stick.
From then on check after a ride.
I also kick it over 4 times or more to prime the oil , before fire up.
