I don't have a means to do this. The manual deconp. is a little smaller than the cabled one it replaced, same threads etc. Needs a washer to insure the seal around it so no exhaust gas will pass by the threads. It remains closed during engine operation and is only opened, by pushing down a small button on the top, about the circumference of the end of your index finger. When it is pushed down it opens a small opening in the bottom, threaded part of the decomp which allows some of the compression to escape up the center shaft of the valve and out of the engine. As soon as the piston fires, the increase in the expanding gases causes the button to be shoved up, closing the decomp valve and it remains closed until you want to release compression the next time your starting the engine. As a matter of fact, the valve closes so fast, you can hear it snap closed. Of course, if the engine doesn't catch on the first try, you have to depress it again to rekick it. If your engine is tuned reasonably well and your starting technique is OK, it should start in one or two trys.Saves wear and tear on the kick start pawl which is a job I don't want to tackle anytime soon.
