Yes, but I accept no responsibility if it:
-melts your dash
-fries your electrics
-sets you on fire
-causes aliens to be attracted and abduct you
Its a CML51:
"Lamp, Incandescent, G-3-1/2 Miniature Bayonet, 7.5 V, 0.22 A, 1 MSCP, 1000 hrs"
Its available here:
http://www.alliedelec.com/search/productdetail.aspx?SKU=7499052I only have a few miles on these bulbs so far, so you may want to wait a bit before ordering; I'll be the guinea pig. It may have a short life because of 2x the spec'd voltage rating, or cause heat issues. Ideally, you'd get a proper 12-14V brighter LED bulb I suppose to be really sure (make sure the LED has a resistor/circuitry to maintain a proper draw or your turn signals wont work properly). I just tried this because I had a couple lying around and I wasn't too concerned because neither the neutral or turn signal bulbs are on for long periods of time on my bike.
(I'll update this thread if I have issues later. If I forget to, reply here and I'll reply.
