Reply #13 on: July 26, 2010, 05:57:33 pm
O.K, Which national lab do you work for? I'm at Brookhaven on L.I. By the way, I opted for the twist gas cap conversion. 3 screws $67 no key. Then you can use the two optical sensors that you allready have.
Logged
