Bullet 500 AVL, 6 months on
32 Guests, 1 User
finbullet
April 30, 2016, 02:11:13 am
Author Topic: Issues with early AVLs?  (Read 2135 times)
LJRead
« on: January 23, 2008, 07:18:25 pm »
Occasionally I have heard rumors of problems with early AVL engines.  One rumor was to the effect that pre 2002 AVLs had "lots of problems".  The other was that the early ones had aluminum tappets which tended to bend.  Sometime later the AVL was upgraded with new alloy tappets.  I will soon have two of the AVL bikes on hand, one a used 2003, the other a new 2002.  I am wondering what teething problems there were and what was done to upgrade them.  Also when were these changes, if any, made?
The two engines will be in the 350 class but I imagine similar issues occurred with the 500s.  Maybe, though, these problems had been worked out by the time CMW started to import them.
Thanks for any help.
Larry
cyrusb
  • Kept man
Re: Issues with early AVLs?
« Reply #1 on: January 23, 2008, 08:51:16 pm »
Aluminium tappets? Could that be true? Lawnmowers don't even come with aluminium tappets. You got me interested in avl engines, it's off to the web.....
« Last Edit: January 23, 2008, 08:54:26 pm by cyrusb »
LJRead
« Reply #2 on: January 24, 2008, 12:57:12 am »
I probably have it wrong - probably meant pushrods :(
cyrusb
  • Kept man
« Reply #3 on: January 25, 2008, 02:09:25 pm »
classics have aluminium pushrods, yes?
Foggy_Auggie
« Reply #4 on: January 25, 2008, 07:29:55 pm »
The classics have steel pushrods as far as I know.  Have to put a magnet on them next time the tappet cover is off to be sure.  High performance light alloy pushrods are an add-on for the classic engine.
Fortiter Et Fideliter
t120rbullet
« Reply #5 on: January 25, 2008, 09:10:09 pm »
The classics have aluminum pushrods with steel ends pressed into them.
CJ
