st. louis
28 Guests, 2 Users
safeer1980, tracendaz
May 01, 2016, 03:07:26 am
Author Topic: Flatter bend of handle bars  (Read 2122 times)
David R
  • Bullet 65, BMW R75/5 Suzuki DR650
« on: December 19, 2007, 07:55:55 pm »
I find the handle bars of my Sixty 5 (which I assume are the same bars all newer Bullets have) a bit uncomfortable. They rotate back more than I would like. Is any one aware of a flatter (straighter) bend of bars that are available? I have the Magura "Euro" bars on my BMW I would like something more like that.
c1skout
Re: Flatter bend of handle bars
« Reply #1 on: December 19, 2007, 09:00:32 pm »
I think that is a commonly copied bar shape, don't order one for a BMW though they are the wrong diameter. Check out a "superbike" bar, I think that would be close. Flanders probably has a website with dimensions but you could find one cheaper from other sources.
David R
« Reply #2 on: December 22, 2007, 07:30:31 pm »
Thanx, yes, I know that the Beemer has a different diameter. I saw a Bullet that had been fitted with bars that I just loved. I thought that the owner said that he bought them from Domiracer, but I looked on their site and couldn't find any. I'll just keep looking.
David R
« Reply #3 on: December 22, 2007, 07:38:09 pm »
I checked out Flander's site and sure enough, their "superbike" bars in 7/8" dia look like what I have in mind. I'm thinking about it.  ::)
Bankerdanny
« Reply #4 on: January 03, 2008, 09:11:13 pm »
Try these guys. They do a drag bar in 7/8 that should work well. http://www.chitownparts.com/
Endeavor To Persevere
RagMan
  • Bulleteer, Uralist &
« Reply #5 on: January 03, 2008, 11:25:13 pm »
Thank you for the link - some very interesting looking stuff there.
aka Indiana Bulleteer.
Jefferson County, WA
cochi
« Reply #6 on: January 04, 2008, 09:24:58 am »
The flat bars look great. I put them on my 03 Classic. The local Honda shop had them in stock. I had a bit of a problem with the installation. Because there is no rise in the bar, at full lock, the switch housings at the end of the bars hit  the gas tank. I found this out the hard way. I managed to put a nice little "dimple" on the right side of my tank. I ended up modifying the fork stops.  Bar end mirrors also look great with this set up.  :D Cochi
Sixty5inILL
  • Sucker for a Pretty Face
« Reply #7 on: January 04, 2008, 10:53:53 am »
My 350cc came with flatter bars and it makes a world of difference.  I'm tempted to do the same to my Sixty-5.  It will hit 50 this weekend here in Chicagoland so I will be forced to take at least one ride.
'04 Bullet Sixty-5 Magic Black
'00 Bullet 350cc- bone stock, Athena Gray
'07 Kawasaki Mean Streak 1600
'67 Moto Guzzi Sport
1979 Honda Twinstar CM185T
1983 Honda Shadow 750
________________________
Homebrewer- Witchy Hilltop Brewery is always open.
