Hi Joe,
Both machines to test the cams and CDI were just 500cc, the one I had was fitted with an open exhaust, 36mm MKII Amal with 280 main jet, shortened barrel and modded piston crown giving 9.2:1 compression, dual valve springs and 19t gearbox sprocket. The head was untouched, although the valves were modified a little. This machine saw 103 mph and 33.5 bhp at the rear wheel.
The second test machine, I posted some cams to the owner to test. He informed me his machine was much closer to standard and runs a 17t gearbox sprocket. this machine reached 95 mph.
Eliminating the valve bounce gives the largest single gain by allowing the engine to rev higher and the power graph to continue climbing.
B.W.
