Kickstart-only Sixty-5 (pic.1)
May 24, 2016, 06:54:33 am
Author Topic: Fold away footpegs  (Read 2466 times)
Sub
  • Bob's Your Uncle
  • 2010 Black Bullet C5
Re: Fold away footpegs
« Reply #15 on: July 16, 2010, 07:53:07 am »
Ya, sees 'bout it!
gashousegorilla
« Reply #16 on: July 16, 2010, 11:30:59 am »
Ya, sees 'bout it!
Alright. when I get  spare moment this week, I'll pull it of the CB750, and try' er on the RE. ;)
gashousegorilla
« Reply #17 on: July 20, 2010, 07:52:42 pm »
Sub,It will work, but you will have to use the  the cb750 peg and arm, mine were from a 78'. But I would say earlier  and later models are probably the same. Remember though, on the right side, it will be right up against the header,so you will have to "adjust" the pipe and or put in some type of insulator, HOTFOOT!!, and your heals are going to be lower on both sides in relation to your gear shift and brake peddle.
 Good luck,let me know,
Dan.
Sub
  • Bob's Your Uncle
« Reply #18 on: July 20, 2010, 08:26:18 pm »
Thanks very much for the leg work.. did you happen to take any pics?!
gashousegorilla
« Reply #19 on: July 20, 2010, 09:40:34 pm »
No, I did not :-[, I'm a dope.
