Taking pics as I go, will be able to post them tomorrow. Gonna hang it up for the night. Most every thing goes together pretty good. Cyclesidecar.com has good instructions for assembly and fitting to the Bike.
I received mounts for a G5 not the C5 that I ordered. I suspect that the C5 mounts are not available yet. I also suspect that the 2011 C5 will have the horn mounted to the motor mount plate like the G5, then the upper clamp will fit without interference.
The Sidecar comes with Luggage Rack, Lights, Tonneau Cover, Tinted Windscreen, Step Plate and Steering stabilizer.
So tonight I got the sidecar assembled. And the upper mount milled to fit around the horn stud. I have pictures of the mods required and will post them.
As for problems so far, (I can skip over not having directions) the holes drilled in the floor of the car that the bolts pass through to hold the seat down go through a support rail, this will prevent being able to put the wing nuts on the studs to hold the bottom seat pad in place. I will have to move it forward an inch and drill new holes.
Including uncrating, taking inventory, assembling, machining the mounting clamp I have about 5 hours into the assembly.
There is some paint damage due to poor packaging, nothing I cannot touch up, and it is not very conspicuous but there is no need of it.
One interesting note, although the unit comes with two lights, a tail light and a fender light, they are markers only, the "taillight" is not a brake/tail, just a taillight. The are also not wired. they have a pigtail about 6 inches long on each. In the box with the accessories I found a roll of wire. Do it yourself!
Quinn
