Military G5 with rear seat
22 Guests, 1 User
Bronwyncarlisle
May 06, 2016, 04:17:53 am
Author Topic: It has begun, perfomance bits on the horizon  (Read 4215 times)
Sub
  • Bob's Your Uncle
  • 2010 Black Bullet C5
Re: It has begun, perfomance bits on the horizon
« Reply #15 on: July 09, 2010, 07:28:14 am »
Yes, I like the look of the cones.
Mcdeeb isnt selling his filter setup. I asked already!
WillW
« Reply #16 on: July 09, 2010, 02:10:24 pm »
Go-faster kits for the G5....?  Oh dear, I can feel the inner nutter stirring    ;D
« Reply #17 on: July 11, 2010, 07:57:41 am »
I think that the UCE can benefit from these things.
It seems to me that the UCE has sufficient compression the way it comes, and the indications are that the bottom end is built well. How much power it will hold is unknown to me, but the odds are that it's good enough to push some extra power with it.
So, that means that things like the Power Commander and breathing improvements on the intake and exhaust should yield some good benefits without having to perform engine surgery.
SSR
« Reply #18 on: July 11, 2010, 12:57:52 pm »
Bottom end is good enough but the connecting rod bottom bearing has to much axial play to start with, resulting in few other issues. I could be wrong though.
Q for Experts, how much axial play in con rod is acceptable? UCE con rod has .20 axial play to start with and I am not comfortable to start with.
« Reply #19 on: July 11, 2010, 02:59:38 pm »
A small amount of axial(side to side) play is normal, and is present on all Bullets. Actually we see up to 4mm of axial play quite normally on the older engines.
Any perceptible radial play(up and down) is unacceptable.
« Reply #20 on: July 11, 2010, 07:32:46 pm »
Ace:
I think SSR has units in inches, because 0.20 inch equals 5.08 mm which is a little more than what you saw (4 mm).
AHS
« Reply #21 on: July 18, 2010, 04:19:18 am »
I was actually thankful that there was really nothing out there for performance bits so I could keep my wallet in my pocket...wallet's now out and waiting  ;D
'10 BRG Electra (G5)
'10 BMW F800GS
'96 Honda NTV650
SSR
« Reply #22 on: July 31, 2010, 02:53:43 am »
Ace:
Singh Ji, I meant .20mm as quoted in the manual. The last time I got the crank changed, I checked the axial play on the old one and it was .70 at each end. Also had radial movement.
Sub
  • Bob's Your Uncle
« Reply #23 on: July 31, 2010, 09:36:35 pm »
Can the UCE EFI/computer handle a exhaust and freer flowing intake system?
 I was looking at the air box today. I think I could fit the Ace on there (but are the ace still available?!).
WillW
« Reply #24 on: August 01, 2010, 03:16:49 am »
It's fine with the exhaust - goes really well with the Watsonian Goldie pipe. Air intake you have to be more careful about. There is a thread here somewhere about why - something to to with turbulence of incoming air.
Thread's called K&N Air Filter for C5
« Last Edit: August 01, 2010, 03:24:57 am by WillW »
1 Thump
« Reply #25 on: November 09, 2010, 01:17:49 pm »
Did anyone try the power commander ?
« Reply #26 on: November 25, 2010, 06:08:37 am »
Its not listed on the manufacturers US website and is listed as "temporarily un available" on Mr.H's website.
Still watching and waiting.
In the meantime there is always this,,
http://www.straightlineperformance.com/catalog/index.php?cPath=221&osCsid=e5f0b349a9784caedf4ba44d0214ec3c
 ;D
Ragmas
« Reply #27 on: November 25, 2010, 08:31:53 am »
 ;D
I have a friend who got into being a machinist due to nitrous oxide.  He was into smoking pot, and into huffing nitrous, he thought, "gee wally, why don't I find a away to make a device that can combine the two?"  Well he started making a thing to do just that when he "came down" and realized that Nitrous is flammable.  At that point he was hooked on the machining bug and has been doing it ever since.
Sam
2009 G-5 Military
Little Falls, NY
