Enfield and I
May 01, 2016, 08:26:18 pm
Author Topic: Need a more powerful alternator  (Read 1363 times)
RBHoge
  • Old Bill
« on: July 04, 2010, 03:06:46 pm »
If there is anything about my 2008 Iron Jug Bullet Deluxe that might be considered a disappointment, it would have to be the headlight. ??? At low rpms it is dim. at cruise it is adequate, ON LOW BEAM.  ;) High beam is worthless. :'(  When the bike was brand new I changed out the dinky 5 1/2 inch sealed beam OEM light for a 7 inch halogen kit from CMW.  The 5 1/2 was about as bright as a match in the wind. >:( The 7 incher can not be aimed, so the "High Beam" goes too high and completely off the road. ::)
I want to add some "driving lights" (mounted to the engine guard) but I doubt that the stock alternator will handle the load.  :o The CMW catalogue shows higher output alternators for the Kick start models, but none for the ES.  :P Does anybody have a viable suggestion?
1972 Honda CB 450 Rufus, Murdered
1978 Triumph T-140 E, Sadly gone
2008 Royal Enfield Deluxe Iron head, " Old Bill"
1971 Honda CB-100,"Kikuchiyo"-traded
O Day 20 Sailboat "Tempus Fugative"
1992 Mazda Miata "Lady Murisaki"250,00miles!
Too many Toys, what else is retirement for?
Re: Need a more powerful alternator
« Reply #1 on: July 04, 2010, 03:48:05 pm »
The SPX003 is the alternator kit I put in my Bullet.
http://www.tri-corengland.com/acatalog/Alternators.html
Check out the test results for the output of this alternator when compared to a standard unit.
2009 HD FLHT Police 103 6 spd
enfield freddy
  • old man riding an old bike
« Reply #2 on: July 04, 2010, 04:01:46 pm »
are you lads in the USA using the AC/DC settup with an altenator with 4 wires , or are you just on DC with a 2/3 wire jobby?
arthritis hurts at my age!
« Reply #3 on: July 05, 2010, 07:54:54 am »
yes there are options...   I mounted an after market driving light and wired it thru the
bright circuit. It throws a lot better beam than my 5 1/2" did. Brother Bong
in S. Korea also mounted a set of driving lights...   I don't think the alt. would handle
them at idle but how much do we idle any way?
              - Mike
Rick Sperko
  • Milwaukee, WI
« Reply #4 on: July 05, 2010, 11:10:11 am »
Switching the remainder of lights to LED allows more juice for the headlight. I believe I saw significant improvement when I did it.
-Rick
Rick in Milwaukee, WI
'06 RE Bullet Classic Iron
'02 BMW R1150R
rideOn
  • And on the eighth day, God said...."Let's Ride."
« Reply #5 on: July 11, 2010, 09:56:49 pm »
i plan to re-wire the entire thing with at least some 12 ga and better connectors and the resistance coefficient should change. if it doesn't make that big a difference with current flow, then spend the dough on high out alt.
'82 gs850gl
'08 v-star 650 classic
« Reply #6 on: July 11, 2010, 10:48:58 pm »
Read this wiring article from Pete Snidal before you wire.
http://www.angelfire.com/biz/snwvlly/bikes/negwire.htm
rideOn
« Reply #7 on: July 12, 2010, 08:37:30 am »
***i add this after a little cyphering***
NEVER, NEVER, NEVER just pull wires out, as suggested in the article. this comes from many years of high-tech electronic work. i would suggest marking the device's polarity, at least, via schematic or circuit tracing and label wiring, if necessary, before cutting wires. a benchmark, or safety net in this case, may be beneficial.
however, a good read. that's kinda what i'm thinking. there are no inspections in this state so i'm considering letting the blinkers go bye-bye. i already use hand signals.
it would be a consideration to wire the blinkers up as running lights, though. i've thought maybe some leds in the front blinkers, mounted to the frame with some bouncy/springy bushings so they appear to 'flicker' at oncoming traffic.
i keep the headlight on hi beam ALWAYS, so i thought i would do like the article says and wire the oem control to simply turn the headlight on and off for starting.
i am considering a good heatsink and a single rectifier and mounting up with the horn to receive good airflow.
thanks for the link, it's a good'ern
« Last Edit: July 13, 2010, 09:02:51 am by rideOn »
'82 gs850gl
arindamcc
« Reply #8 on: March 27, 2013, 12:32:38 am »
Which regulator/rectifier you used with your sparx 3 phase stator ? if possible please post some picture.
« Reply #9 on: March 27, 2013, 02:14:27 am »
Electronic flasher, l.e.d.'s and Bosch pn#  0 301 600 118  ;)
« Reply #10 on: March 27, 2013, 12:00:49 pm »
My G5 had a terrible headlight, so I ended up running a hot wire from the battery through a couple of relays and directly to the headlight. The wires from the dimmer switch controlled the relays. Worked great!
