WPB,FLA
February 08, 2016, 02:42:43 am
Author Topic: 18 tooth counter shaft sprocket  (Read 4343 times)
Bankerdanny
Re: 18 tooth counter shaft sprocket
« Reply #15 on: January 03, 2008, 08:54:55 pm »
I have the 18 tooth sprocket in my tool box waiting for warmer weather (I am in Chicago) to install (along with heavy duty clutch springs and the shifter improvement bushings)
I installed the 7" halogen headlight conversion last fall. What a huge difference. It is like I didn't even have a headlight before.
Endeavor To Persevere
RagMan
  • Bulleteer, Uralist &
« Reply #16 on: January 03, 2008, 11:26:46 pm »
Going to work in a Psychiatric Unit, on a Bullet. Sounds kind of right, doesn't it. :)
aka Indiana Bulleteer.
Jefferson County, WA
cochi
« Reply #17 on: January 04, 2008, 09:10:51 am »
Ragman, you are absolutely right! As the old saying goes, "you never see a motorcycle parked in front of a psychiatrists office". Tinkering and riding this marvel keeps me sane!!  However, some of my coworkers think I'm a little "touched in the head" for riding an "antique". They, as of yet, have not discovered the zen of maintaining and sometimes even improving a machine.  It becomes a part of you.        Bankerdanny, one of the mods that I made to my Bullet was the heavy duty clutch springs. It made a big difference. The clutch grabs nicely and there is no slip. I still have the older 4 plate clutch and it tends to drag a bit when it gets hot in stop and go traffic. I use the neutral finder quite a bit and it helps.  I also want to see if the improved "clutch release pad" that I just installed will help. I'm also looking forward to being able to See at night with the new 7" headlight.  Thanks again to all of you.
« Reply #18 on: January 04, 2008, 11:28:37 am »
Ain't that the truth!
If I could only find a way to bottle up that warm & fuzzy feeling to get me through the winter!
CJ
