Damn.
Stock battery? Time to change it
It is nearly 3 years old, so I silently counted on it being decrepit.
Alas, all tests showed it is in good working condition.
The coupler to the RR unit seemed to be not tight. I pressed it together.
Then I was called away. Damn, further testing postponed till tomorrow.
@High on Octane
Alternators are mighty expensive.
This Electra's casing is still tight fitted.
But there have been mystery blow-outs from the oil pump into the airfilter (not because of overfilling; level is below 50%). All that is behind this casing. Cursed cover?
Bottomline, I have three bikes and I can't ride none of them.
Six wheels, still condemned to two legs. Purgatory, things can only improve.
