at the hanger 2
May 05, 2016, 08:42:14 pm
Author Topic: What did you do to your Royal Enfield today?  (Read 356503 times)
« Reply #3585 on: November 03, 2013, 06:25:12 pm »
Reaching home I parked it on its center stand before switching off the engine, walked up to the mail box & back, & MY SIGHT GLASS WAS TOTALLY FULL UP.
You should turn it off and let it sit on the center stand for a few minutes while you take your gear off, then check it. it should be about the middle of the glass.
Check it in the same spot every time, pointed the same way. If your garage has any slope at all it will read differently if checked in another spot or orientation.
« Last Edit: November 03, 2013, 06:28:28 pm by barenekd »
« Reply #3586 on: November 03, 2013, 06:29:50 pm »
Took another shot at soldering my broken oil feed line and finally nailed it!  I seriously tried soldering this damn thing a dozen different times.  It was either still leaking, or crooked or whatever.  But I went out to the garage early this morning and gave it another go with a slightly different technique and now it doesn't leak a drop.   :D   So after that I decided to take advantage of the beautiful fall weather today and went down to the car wash and gave her a nice bath and washed off all of the spewed oil.  After I had The Blackhawk all shiny again I took a cruise around town rattling all the Sunday drivers' windows.   ;D   The bike is running soooooo good, but the clutch is cooked.  Anything over 1/3 throttle at 4000+RPMs and the clutch just breaks loose.  Still a blast to ride!   ;D
Royalista
  • phaneropter
« Reply #3587 on: November 03, 2013, 06:53:06 pm »
It feels so good when a repair succeeds and holds at last.
Relax, enjoy the pause...  ;D
moriunt omnes pauci vivunt
DanKearney
« Reply #3588 on: November 03, 2013, 10:10:25 pm »
Nice work Scottie,
I took the RE out today also.  Looped through Central City, then down to Evergreen and the Kerr Gulch cutoff down to 74 and into Morrison for lunch.  Then back up Golden Gate Canyon/Crawford Gulch to home.
Was a great riding day today.  I don't know how many more are in the cards for us out here for the rest of the year.
Cheers,
Dan K.
« Reply #3589 on: November 04, 2013, 07:08:16 am »
.......Was a great riding day today.  I don't know how many more are in the cards for us out here for the rest of the year.
Cheers,
Dan K.
I know!  67*F yesterday and supposed to snow tomorrow!  At least we live in Colorado and there will probably be some nice riding days in December and January when the likes of riders in the Midwest huddle around their fireplace.   ;D
« Reply #3590 on: November 05, 2013, 07:21:18 am »
Readjusted my valve lash last night.  Even at .005 lash, the motor is just so noisy.  Which is weird because the manual calls for .005 lash when "the motor is at constant higher RPMs".  It was so damn loud on the highway it was making my ears ring!  Uurrrrgh!  So I went back and set them the same way I did last time, basically set the valves as tight as I could and still hear a "tick" play in the rocker.  Didn't finish until late tho so didn't get a chance to fire and warm it up.
« Reply #3591 on: November 05, 2013, 10:12:15 am »
From what manual did you got that .005" number? That doesn't sound like an RE produced Manual.
The bike is supposed to have zero lash, just loose enough to be able to spin the pushrods.
« Reply #3592 on: November 05, 2013, 10:58:48 am »
I was wondering the same thing, though the zero clearance is for the singles.  Not sure what it's supposed to be on twins.
« Reply #3593 on: November 05, 2013, 11:15:47 am »
Right out of the Constellation manual.  Look at the very bottom.
« Reply #3594 on: November 05, 2013, 11:28:15 am »
My old book says .002" for the exhaust and that's for all Enfields including the Bullet.
« Last Edit: November 05, 2013, 11:31:09 am by barenekd »
« Reply #3595 on: November 05, 2013, 11:51:35 am »
I have copies of the original manuals.  They must have changed the clearances later after they realized that .005 is too damn noisy.
« Reply #3596 on: November 05, 2013, 12:37:58 pm »
Kinda makes sense to run a little more clearance on the exhaust.  They get hotter and tend to grow a bit more, especially if you're running at continuous high speed.
Never saw another engine that called for zero clearance before the RE.
heloego
« Reply #3597 on: November 06, 2013, 10:29:29 am »
Got rid of the OEM trafficators and installed a set of Bullet Turn Signals PN Z90457 w/the 2" stems. Definitely looks more better.  ;D
« Last Edit: November 06, 2013, 11:43:38 am by heloego »
« Reply #3598 on: November 06, 2013, 11:34:57 am »
Very nice!   :D
heloego
« Reply #3599 on: November 06, 2013, 11:52:07 am »
Thanks, Scottie.
After posting the pics I decided I dislike the gaiters so much I cut them off.
Spent 3 hours getting them on, and 5 minutes getting them off.  ::)
